Vacuum Pump Manifold http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=6329 |
Author: | RussellR [ Mon Apr 24, 2006 8:08 am ] |
Post subject: | |
As some of you know I am working on switching over to vacuum for bridge clamping intially, and I would at some sttage like to add a workholder. I have seen the LMI System on there site and wondered what does the Manifold do ? Russ |
Author: | russ [ Mon Apr 24, 2006 7:19 pm ] |
Post subject: | |
Russ, The manifold is a piece that allows attachment and distribution of your vacuum lines. The LMI manifold will accpet quick connectors (Pisco connectors), vacuum gauge, pressure relief valve, etc. It's a very straightforward setup...you attach your vacuum source to one end, your relief valve and gauge in the middle, and a Pisco connector on the other end that connects to your vacuum fixture. |
Author: | RussellR [ Mon Apr 24, 2006 7:24 pm ] |
Post subject: | |
Russ Thank you. |
